Low enough?
Low enough?
Before
After
The front is down a bit now. I have the 1" Shelby drop and cut half a coil off the springs with a cut-off wheel. I need to get block to lower the rear but how does the front look?
After
RE: Low enough?
ORIGINAL: dcohen
dekalb? borden's dairy?
somebody knows about some agriculture
RE: Low enough?
ORIGINAL: superdavid
Nice. I'm wanting to do it as soon as I get home. My rear has been lowered about 4" from where it sits in my sig pic, but the front is still at factory height. How wide is your front tire?
The Stangs always sat too high in front in my opinion
RE: Low enough?
Maybe you should have went with the reversed eye. It seems like you would need to drop about 3 inches or so to be even- but this is from looking at the pictures. Also, did you want the car to sit high in the rear?
