C4 to manual conversion in a 70
Old 11-15-2007, 12:45 PM
subzero05
subzero05's Avatar
Default C4 to manual conversion in a 70
Hi All. I need some help and can't seem to find the answers anywhere on the 'net. I have a 70 fastback with a C4 in it now and want to install a T-56 into it which I also have. Now, problem is I can't find a clutch pedal assembly out of a manual 70 car anywhere and the only reproductions are for the 65-68 cars that I've seen. Nobody that I have found has a re-pro unit for the 69-70 cars so basically I would have to locate one out of a wrecked car somewhere which appears to be quite the process to say the least.. So, my question is has ANYBODY done a retrofit and installed say a assembly from a Fox Body 79-93 ish car with the quadrant etc into this year car?. Obviously , this is much easier to get ahold of if someone has made it work?...Any help would be appreciated...Thanks
subzero05 is offline
Old 11-15-2007, 01:00 PM
Gary H
Gary H's Avatar
Default RE: C4 to manual conversion in a 70
http://www.moderndriveline.com/md_faqs/CC_1.shtml
or
http://www.ronmorrisperformance.com/
Not sure what the difference is between 68 and 70. There's one on ebay now but it's $500.
Gary H is offline
Old 11-15-2007, 03:05 PM
pushrodpower
pushrodpower's Avatar
Here are two rescources for used parts.
http://www.jkmustang.com/jkmustang/
http://www.am-mustangparts.com/
pushrodpower is offline
Old 11-15-2007, 10:14 PM
subzero05
subzero05's Avatar
ORIGINAL: Gary H
or
i tried bruce at Modern driveline and he advised me the 68 pedal won't work on the 69 or 70 cars. I saw the $500 one on ebay..OUCH!..I may have to go that way though unless some other option is avail.
Old 11-15-2007, 11:12 PM
andrewmp6
andrewmp6's Avatar
Try emailing http://www.perogie.com/ or one of the mustang junkyards in the faq or even post a wanted add on here.
andrewmp6 is offline
Old 11-16-2007, 10:14 AM
pushrodpower
Deleted double post.
Old 11-16-2007, 11:09 AM
chillininnh
chillininnh's Avatar
It sucked doing so but I ended up buying complete support with pedalson ebay in order to swap the FMX for a TKO 600. I would think someone would be working up a repop for these as we speak.
chillininnh is offline
Old 11-16-2007, 02:29 PM
BigIron22
BigIron22's Avatar
I ended up buying a refurbished support, clutch and brake pedal assembly from someone on ebay. you don't need the support. And the support is different from 69 to 70. i searched for months for a repop or one from a junk yard no luck.
BigIron22 is offline
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
BeatnikFink
10-01-2015 08:00 PM
guitarman376
09-30-2015 05:54 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: C4 to manual conversion in a 70
