6 cylinder motors
RE: 6 cylinder motors
you can get a ton of info for your 6 at www.classicinlines.com i dont remember of hand but it to do with the # of freeze plugs it has 5 is a 200 or a 250 i think 4 or less is a 170
If you have 5 freeze plugs on the side, it's a 200. If you have 3, it's a 170. You can decipher this by the numbers, but it is easier visually. Also note, if you have a 170, you only have 4 main bearings. If you have a 200, you (probably) have the 7-main bearing engine. It's bulletproof
logan409
09-26-2015 07:43 PM
