I am thinking about installing EFI on my 70 fastback (Long way to go though). I found the retrotek EFI system and was wondering if anyone had tried this system. It loos like a carburetor and bolts onto a regular carburetor type intake manifold. Her is the manufacturer's website.
You don't have to buy anything else. it comes with the computer. The price is cheep if you consider buying a EFI unit, intake, throttle body, injectors, rails, fuelpressure regulator and maybe a mass air unit depending on the computer. Now when you look at this then the Retrotek is not so bad. I like it a lot, even good for supercharging and it has a variable output so you can use a single line for the fuel pump (no return line).
Its self tuning and its efi its a step up from a carb but not quite the muilt port injection.I havent used that but there push button shifter i put on a 32 ford kit car my uncle bought it worked great easy to put on and set up.
