booo
booo
well the exhaust is all finished now. the shortys didnt seem to add much or any sound at all. i havent really gave it a good rev yet but they dont seem to be really agressive. maybe a bit more throughty. so whats next?
h or x pipe? ill be getting about 100 extra buckaroos tomorrow for a small job so that should cover a custom one from the shop. is x or h better for sound, performance (one torqueyer or more hp?)
give me your knowledge!!
will that add a significant change in sound? itll equal it out obviously
RE: booo
h or x pipes will only make it quieter in terms of sound(generally) but you'll pick up torque(usually). x's work a bit better, but are also harder to fab so they cost more. The 2 biggest things(other than engine power output) that effect sound are mufflers and pipe diameter
RE: booo
yeah its fine. i was jw if the x or h made a diff. it sounds great. its bone stock so a cam will def. add to it. i have super 44 flowmasters and shorty headers. oh btw. i know the mufflers have to get broken in but do the headers also with the heat over time?
RE: booo
ORIGINAL: jcomp
1970: I'm going to unofficially declare you "Mr. Obsessed With How His Engine Sounds 2007"
RE: booo
If it's stock then you might as well stay 2.25". An x or h pipe may mellow it out some, but you'll prolly pick up power, so it can't hurt. You could bump up to 2.5" and get a bit more sound out of it, and with 351 cubes it shouldn't hurt your power that much, maybe not even enough you'd notice, but it will give you room to grow as well
