I6 swapped for 289 - What next?
I am planning ongetting a '67 with a recent 289/c4 swap from the original I6. It still has the smaller rear with 4 lugs in the front and rear.
This car will be more of a local driver and wanted to know what benefits there would be to upgrading rear end versus costs? What else should I consider upgrading to front end and costs? I have already explored going to discs up front. Thanks to those who posted on my previous posts.
RE: I6 swapped for 289 - What next?
You need to change the front springs the hubs and brakes rear end is a must the 7.25 in it is weak i had one in a ranger and i exploded it with the 2.3 lol.Cheapest place i trust to buy one from is http://www.perogie.com/Rears.htm he sells used housings you can use 28 or 31 spline axles lsd or not gear ratio is up to you.If you want baer brakes cheap http://www.mustangsteve.com/cobrabrakes.html the cbora brakes are pbr same thing baer really is and alot cheaper but need 17s to clear them.
Matt's 95 Stang
10-05-2015 07:16 AM
