I need a crash course on fuel mixture adjustment.
Old 11-20-2007, 09:14 AM
halsted
halsted's Avatar
Default I need a crash course on fuel mixture adjustment.
I have a '65 coupe with autolite 2100d carb. When I did tune up, plugs were sooty. Wondering I f I am running rich. Can anyone take me thru an adjustment sequence. I have a tachometer. Do I need a vacuum gauge, and if so, where does it hook up to. I appreciate any help. This is my first project car.
halsted is offline
Old 11-20-2007, 12:06 PM
crey
crey's Avatar
Default RE: I need a crash course on fuel mixture adjustment.
You should get yourself the Ford factory repair manual. They have a large section on carburators including stuff on setting the mixture. I'll be adjusting my carb as soon as the rest of the car is ready to go. Just make sure you read everything completely. I usually just skim over the steps, screw things up and have to redo everything after reading how to do it right.
crey is offline
Old 11-20-2007, 12:09 PM
silverblue66
silverblue66's Avatar
Ditto on the repair manual.
kip
silverblue66 is offline
Old 11-20-2007, 01:10 PM
NorCalTroy
NorCalTroy's Avatar
Using a vacuum gauge is one of the best ways to tune a carb.
Here are a few links to read through to help you out. They don't all pertain to your setup, but the information will probably help you out never-the-less.
http://www.automedia.com/Carburetor-...es20040401cj/1
http://www.fordmuscle.com/archives/2...ockCarburetor/
http://www.jason.fletcher.net/tech/c...carbtuning.htm
http://www.carcraft.com/howto/ccrp_0...cks/index.html
http://www.bob2000.com/carb.htm
Good luck!
NorCalTroy is offline
Old 11-20-2007, 02:35 PM
jlg2002
jlg2002's Avatar
And in addition to the others:
1. make sure the throttle shaft is not worn out ( it will move laterally (back and forth & not in and out) in the hole if it is) Stop and replace the carb.
2. Run both fuel mixture needles all the way in until they seat (lightly). It should be around 1 1/2 to 2 turns.
3. Turn each ofthe idle screws outward 1 1/2 turns.
4. Start the engine and set the idle to around 700 in neutral or park.
5. Using a tach, rotateeach idle screw, in or out, until the maximum rpm is obtained, reset the idle to no more than 700 rpm if it starts to go higher than 850 or so.
6. Now with the vacumn gauge, tweak each screw until maximum is arrived at it should be in the 18 to 21 inch range and steady.
7. Reset the curb idle in N, if standard, to 550 to 600 or to the sameRPM in drive if an automatic.
8. Don't forget to check /replace the air and fuel filters as part of your tune up.
jlg2002 is offline
Old 11-21-2007, 07:05 AM
falconfixer
falconfixer's Avatar
Before you go indepth - a quick check is to take off the air cleaner and start the engine (warm). Close the throat with your hand - does it stumble or rev? If it stays the same RPM until you almost completely cover it - then it is okay.
If it does change - the steps above are excellent!
falconfixer is offline
Old 11-21-2007, 01:49 PM
halsted
halsted's Avatar
Thanks to all. I will work on over long weekend. Happy Tday to all.
halsted is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: I need a crash course on fuel mixture adjustment.
