desktop dyno
desktop dyno
can anybody who has a desktop dyno give me a ballpark for this setup?
289 std bore
8.7:1 compression
comp cams FS XE250H dur @ .05206/212 lobe sep 110 lift .46/.474
stock heads mild street porting
cast iron intake port matched to heads
autolite 4100 480cfm
289 hipo manifolds
2 1/4 duel exhaust with turbo mufflers
2.8:1 open rear end
c-4 trans
anybody know what my hp tq would be?
Kip
289 std bore
8.7:1 compression
289 hipo manifolds
2.8:1 open rear end
c-4 trans
Kip
RE: desktop dyno
I like the stock look. and some porting does wonders for 289 cast iron heads. The carb is sized right and is the righte size up to 8k rpm at 80% ve. I have a stock bottom end so I wont spin it past 6800 so the carb should be fine.
Besides, I dont need to be tempted with too much power.
