67 mustang t-5
RE: 67 mustang t-5
maybe a bent axle or an imbalanced wheel. ive also heard that sometimes wheels with a uni-lug pattern can cause vibration at higher speeds but i was running uni-lugs a while back and never had a problem.
RE: 67 mustang t-5
Is the driveshaft new could be alot of things a bearing in the rear end a out of balance rear tire or even the driveshaft or bad u joint.Id try the cheapest thing rotate your tires see if it stops or move to the front if its still there then its driveshaft or rear end how good are your shocks.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
