Where to find oversize Rear Main Seal?
I just replaced the rear main seal in my 289. STILL LEAKS!!!!!! Where can I find an "oversize" seal, and how much oversize should it go? I did the replacement without pulling the transmission. Just removed the crossmember, dropped the pan, loosened the journals took the last onecompletely offand removed/replaced the old seal. I didn't realize I could get "oversize" seals, or I would have done that in the first place!!!!! THis is the 2 piece rubber seal with a steel core.
RE: Where to find oversize Rear Main Seal?
i dunno, but you can get a "seal saver" and knock that on. it will make your crank a little larger OD where the seal rides on.
btw, they are a pain in the @ss to get on [8D]
felpro has a hipo rear main seal, part #2901, if i'm correct. I have thesame problem using stock seal. also, there might bea tiny bevel in topedge of the bottom mainbearing cap, which requires a tiny bead of gasket sealer.
Thanks for the interesting stories and moral support, but with this being such a prevalent problem, there MUST be an "oversize" two part rear seal made which has a slightly larger INNER DIAMETER to hug the crank OD at that point. If there's anyone who knows a source of such a part, PLEASE chime in. I only want to do this ONE MORE TIME.[]
