Rusted fuel tank?
Old 11-28-2007, 02:50 PM
kaiser18
kaiser18's Avatar
Default Rusted fuel tank?
Is there a decent way to check if the interior of your tank is rusted? Iam thinking about replacing mine, as far as i know its the orignal fuel tank. I just fear that it might be putting crap in my engine.
kaiser18 is offline
Old 11-28-2007, 03:03 PM
dozierstang
dozierstang's Avatar
Default RE: Rusted fuel tank?
Replace it...it is not that expensive. Get a new sending unit too. All that = peace of mind.
dozierstang is offline
Old 11-28-2007, 07:03 PM
zmetalmilitia
zmetalmilitia's Avatar
May as well replace it. Especially if its original. You can find kits for around $100-$130, pretty reasonable and an easy task to do.
zmetalmilitia is offline
Old 11-28-2007, 07:51 PM
109jb
109jb's Avatar
I would replace it. As was already said they don't cost that much, but if you have a good fuel filter you won't be putting crap in the engine even if the tank is rusted.
109jb is offline
Old 11-28-2007, 08:12 PM
rbrown22
rbrown22's Avatar
Just install a good inline fuel filter and run it a day or so.... Then check the filter.... They also have some clear fuel filters that have replacement fuel filters. I have one on my '83 Chevy K10..
rbrown22 is offline
Old 11-29-2007, 11:55 AM
LPlum
LPlum's Avatar
I would just replace it. So you don't have a problem like I did. I was out of town for a long weekend. My neighbor called and said there was gas running down my driveway from under the garage door. The gas tank rusted through just a pin hole but 10-12 gallons later. What a mess we had and it took months for the gas smell to dissapate. I'm lucky the housedid not go up in flames.
Lowell
LPlum is offline
Old 11-29-2007, 01:08 PM
zmetalmilitia
I had the same thing happen to me too, in my 70 coupe. Filled it up one day, the next day when I went to leave for school, no gas.[:@] It all leaked through a rusted hole in the tank.[:@] That was back in high school-1989, luckily gas was only $1.10/gal. The good ol days.
Old 11-29-2007, 01:48 PM
boogerschnot
boogerschnot's Avatar
ORIGINAL: zmetalmilitia
In1989 gas should have been about $.60 per gallon.. You must be running jet fuel
boogerschnot is offline
RolandT3Speed
RolandT3Speed's Avatar
The only really good way to check it is to remove it.
If the tank is rusted you can get it cleaned with caustic soda and plastic coated on the inside or just buy a new one one because it's cheaper than cleaning & coating.
RolandT3Speed is offline
Old 11-29-2007, 01:50 PM
TexasAxMan
TexasAxMan's Avatar
ORIGINAL: boogerschnot
Yep, I remember paying $0.989 in 1998, so I think your price is a little off.
TexasAxMan is offline
Quick Reply: Rusted fuel tank?
