reading spark plugs - one is different?
RE: reading spark plugs - one is different?
Yeah. I remember you blew the last motor up. LOL!!!
Maybe you should try something that isn't related to the Pinto or maybe just give it up all together and BUY a Pinto.
Like the one I posted before and than you and the guy around my way who's got a jacked up late 80's Crapmaro with 36 inch swampers on it can hang out together.
I dunno man. Try cleaning them off really good and run it again. Maybe someone got a small amount of oil into the cylinder and that's the end of it. Clean 'em run it and check it again. If it's the same, you've got a problem. GL!
ORIGINAL: my77stang
i just made the wires and the cap is brand new. checking them is no big deal, i can do that. i'd rather think maybe one of the older wires was bad but we'll see.
dont ***-u-me anything
It looks like it's not firing. It could be electrical or mechanically based. Obviously, check your wire and cap, ( i know you did this already) Change it with a known good plug and then do a power balance check on your #5 to see if the rpm drops when you pull the wire.
mechanically, (slim chance) lack of fuel or compression.
replaced that one plug, got car back together, drove around the block a few times and it looks as clean as the rest - musta been a bad plug or just a fluke[8D]
