c4 to t5 conversion kit
any of you guys know where to get a conversion kit - with all the parts- for a c4 to t5 conversion for a 67, 289.
found one at modern drive line but was wondering if there was another place to shop.
RE: c4 to t5 conversion kit
ORIGINAL: woodywrkng
Windsor-Fox used to, but I notice their website is gone. Dunno. Mustangs Plus has several items for the swap, but I don't think they're in kit form.
These guys not cheap but very good products. Even tho I had a toploader 4 speed I bought the TKO swap kit for a automatic. You may need to get a cluth pedal I think. Everything else came with the kit. I switched from a 289 to a 5.0 based 347 so fly wheel to drive-shaft they provided me.You can upgrade any parts or tell them you on a budget they will work with you.
http://keislerauto.com/ford/transmis...tang_65-70.asp
ORIGINAL: jroseman
i have talked to bruce at modern drive line and they have everything i need. i just wanted to shop around.
is the t5 worth the swap and the 3500+ it will cost?
Monitor Ebay for a lot of these parts. I routinely see pedal assemblies and other needed parts on there.
Good luck!
Jeff
jwog666
12-27-2021 08:09 PM
