Another lincoln 5.0 question...
Old 12-09-2007, 09:42 PM
  #21
tarafied1
tarafied1's Avatar
Default RE: Another lincoln 5.0 question...
The AOD has overdrive, drive and low (3 forward gears) and the original shifter has 1, 2 and drive (3 forward gears. Where you will run into trouble is the shift selector lever length. I swapped a HO 5.0 into my T-Bird and the V6 AOD had a shorter lever. That meant the shifter and trans didn't line up. I swaped the lever and that fixed it. I put a C6 in my 67 and had a simaler issue. The C4 lever fit the C6 and that fixed that issue. So I'm saying the lever length on the AOD may need to be modified but in theroy the shifter should work.
As for engine color, do want you want. I painted my engine red but car is red. It will all depend on the rest of the car...
tarafied1 is offline
Old 12-09-2007, 11:04 PM
  #22
outlaw66
outlaw66's Avatar
Thanks everybody. I'm sure i'll have more questions to come, so I'll tell you how everything goes.
outlaw66 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: Another lincoln 5.0 question...
