Brake Booster help!!!
Does anybody know what modifications are neeeded to my brake pedal carrier in order for it to accept my power booster?
1968 mustang 289 manual drum brakes to power disct
donor car 1969 mach 1 power disc
Kip
Kip
RE: Brake Booster help!!!
On my 66 - I just had to use an adjustable rod - the other thing that I had to do was to use some brackets for the booster and widen the opening in the firewall so the booster would not sit too low and interfere with my clutch rod ... but that was on a 66 ...
i just did this on my 67 hope this helps! , i had 4 wheel non power drum, to 4 wheel disk!
you need to ditch your old brke pedal and get a power berake pedal, then it axtually attaches hights on the mount, there is a hole for it and when you get the new pedl it will come with all supplied hardware see pics below
see the 2 brake pedals , tops is manual brakes, lower is power that does not attach with the clutch it attaches higher on the very top pic in the hole i circled! just a fyi you can get a 4 wheel power disc brake booster and master cylinder for 150.00 thats what i did and it was a direct fit, and lifetime warranty!
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
