Does anyone know how to...
RE: Does anyone know how to...
If the paint is priority - rent the tool. There is an on-line site that will mail it to you & you return it.
If not - just be patient with the bat - many rolls - a little at a time. Warm the paint if possible.
stick the handle of the bat in between the tire and the fender roll it foward slightly then do it again witha lttle weight iver the flare etc till you get it where u want it just do it slowly
You also want to heat up the paint so it doesn't crack also. I had luck in the past with the roller that hooks to the rotor and gradually rolls it out. If you have a small torch, what I did was heated it from the inside just enough. As a matter of fact, I think it was in the directions for the eastwood roller, It's snowing out and I'm not looking for the book now.
