HP vs TOURQUE
HP vs TOURQUE
im building a 66 mustang and want maximum speed/performance out of it, the question is if i should put a stroked 351 for huge torque (less rev) or rebuild the 289 thats in it and get high revving hp moter? im very confused as to wich will work better in a semi light car. what do you guys think? help please!
RE: HP vs TOURQUE
I would go with the bigger engine.To spin a 289 faster than the 351 will cost more because the stress on the crank and rods will be higher.You could build the 351 just as strong and spin it just as fast with bigger HP gains and about the same money.
RE: HP vs TOURQUE
yea if I remember correctly I don't think it was settled
Its funny how a nitrous stang with 390 rwhp and 500 rwtq is slower through the 1/4 both et and mph wise vs a stang with 25 more hp and 125 less tq [] It ain't about how much torque you can put to the tires, its about getting the tires moving the fastest
RE: HP vs TOURQUE
its all about hp & the practicle aspects of using it. meaning you build the motor for hp, then you gear it so you can be in the peak range most of the time for whatever you are doing.
torque & hp tell 2 sides of the same story. one describes a force (torque) the other the amount of work you can do with that force (hp).
