Thermostat
Old 12-17-2007, 12:12 PM
Matt.69Stang
Matt.69Stang's Avatar
Default Thermostat
1969 Mustang Coupe, inline 6. I had to order a new thermostat housing but I also ordered a thermostat for it at the same time since it also needed to be replaced. I purchased a 195 degree one, but started thinking, is that too high, or will it hurt the car in any form? It wasn't like I blindly bought the 195 degree one, because it was listed on CJ Pony Parts with the housing.
Any problems, or should I get a lower one, like a 180 or 185?
Matt.69Stang is offline
Old 12-17-2007, 02:13 PM
Mustangdemon67
Mustangdemon67's Avatar
Default RE: Thermostat
i think the stock one is about 180? im not sure, but you should be fine with what you have. these older engines run better when they are warmer as opposed to cold. what size radiator do you have? still have the stock water pump? these will play a big role too if your car gets too hot.
Mustangdemon67 is offline
Old 12-17-2007, 02:28 PM
Matt.69Stang
nope, the radiator was bad and leaked when I went to fill her up, so I have a new radiator, and I figured while I was at it, I'd do the water pump as well.
So, there's a new:
thermostat housing
thermostat
waterpump
radiator
new hoses
Old 12-17-2007, 02:36 PM
Mustangdemon67
yeah you should be ok then, with a nice flowing radiator / water pump the temp gauge most likely wont go past half
Old 12-17-2007, 02:38 PM
Matt.69Stang
good news to hear.
I hope she starts soon. I need to put the new starter on, hook the hoses up, add coolant, (maybe a new battery) and fire her up.
Old 12-17-2007, 06:21 PM
mustangmatt63
mustangmatt63's Avatar
With a good radiator and water pump you should be just fine!![8D]
mustangmatt63 is offline
Old 12-17-2007, 06:54 PM
green_blurr
green_blurr's Avatar
i had a new radiator and i was running a 195 degree thermostat it ran at about 205' which isnt bad instead i went to a 180' so that would be putme at about 190 just letting ya know you what you can get away with.
green_blurr is offline
Nick Oliver
10-17-2018 04:22 AM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Wesley1995
08-30-2015 02:01 PM
Quick Reply: Thermostat
