351 Windsor
351 Windsor
Hi, I want to install a 351 Windsor engine it is a 1974 model and I have a 1970 fastback will it slip right in without modifications? what is the last year that 351 windsors will fit? Thanks for any feed back
smokee
smokee
RE: 351 Windsor
It will fit, will need the 351 brackets for the alt, A/C PS, etc.... I think you will need a 351 flywheel and balancer as well for the right imbalance. (or are early 302s 50 oz. ?? I don't think so..) Your exhaust manifolds should work, or if you have headers they might work.
All of the above assuming a 302 is in the car now.
Mounts and most other parts are the same, 302 intake manifold wont work.
RE: 351 Windsor
Maybe my question should read; what yearwas there a change from the 351 windsor that came in 1969 mach 1 to the newer engine/ electrinic ignition. I have a chance to get a 1974 windsor and seems like there is a change around 1972 or 74 to where it is more of a pain than using the "early block)
RE: 351 Windsor
ORIGINAL: smokee23
Even the last 351 W produced (1982?, 1988?) will bolt in with minimal issues.
RE: 351 Windsor
If you are talking about putting a 351W into a 1974 Mustang II, it will fit but she's a tight squeeze. I did one in 1986 for a buddy of mine and we used headers for the 302.
Not sure what change you are talking about on the 351W. The deck height changed from 9.48 to 9.5" in 1971, I believe,but that shouldn't impact what you are doing.
bradleyb
11-27-2015 07:50 PM
Mustangs of Illinois
08-22-2015 10:00 PM
