87 8.8 in my 67
Old 12-18-2007, 05:52 PM
SalikDDD
SalikDDD's Avatar
Default 87 8.8 in my 67
well, my friend purchased a wrecked 87 gt for some parts and has the rear left over - what's it gonna take to adapt it to my 67? i know it's about 1/2 wider (big whoop) but the driveshaft length shouldb e the same right? and i'd have to mod the spring perches correct? any sites with info on it or a write up?
SalikDDD is offline
Old 12-18-2007, 07:37 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: 87 8.8 in my 67
why waste the effort..find a 9 inch and it'll bolt right up and be stronger
mjr46 is offline
Old 12-18-2007, 07:54 PM
Starfury
Starfury's Avatar
And heavier. And possibly not the right width.
I have a fox 8.8 sitting at a friend's place waiting for me to build it. The width is perfect for 67-78. You'll need to dig up some ranger axles and get the spring mounts changed, but it's not that big a deal. A good driveline shop should be able to do it for you and get the pinion angle correct.
I'll post the donor vehicles you can steal parts (axles and brakes) from later tonight when I get home.
Starfury is offline
Old 12-18-2007, 08:07 PM
mjr46
mjr46's Avatar
ORIGINAL: Starfury
with the proper research the right one can be sourced.....just gotta know where to source one from..besides I build my motors powerful enough that the little extra weight of a nine inch is of no concern
mjr46 is offline
Old 12-18-2007, 10:22 PM
Starfury
Starfury's Avatar
Doesn't matter that much in a straight line but if you plan on turning the car (I'm more of a road course kind of guy), all that extra weight in the *** end doesn't help. And it's pretty hard to break an 8.8 with anaturally aspirated289/302 (even a stroker). If you can get your hands on one for really cheap (or free), I'd consider it a good deal. The only real downside I see with an 8.8 is that it's not a removable carrier design, which can suck if you want to change the gears down the road.
Axles:
Twod-side side axles from an 83-92 Ranger/Bronco II with a 4cyl or 3.0 V6 and7.5" rear, or two p-side axles from an 86-97 Aerostar.
Brake drumscan come from any of the same vehicles.
Starfury is offline
Old 12-18-2007, 10:28 PM
andrewmp6
andrewmp6's Avatar
A 9 inch is stronger then a 8.8 that 8.8 might fit with some work cuting off all the mounts and welding on the spring perchs id like the rest of them get a 9 inch.
andrewmp6 is offline
Old 12-18-2007, 10:46 PM
mjr46
mjr46's Avatar
ORIGINAL: Starfury
Axles:
gotchaI'm more of a straight line guy......I love my removable carrier in my 66.....makes a gear swap a breeze..If I'm quick less than a hour
mjr46 is offline
Old 12-18-2007, 11:20 PM
mustang289
mustang289's Avatar
I really need to learn how to change R&P's, its something i've always said i would do, i've built motors, trannys, done everything else, maybe someone can make it a sticky? hint hint....
mustang289 is offline
Old 12-19-2007, 02:09 PM
tarafied1
tarafied1's Avatar
ORIGINAL: Starfury
I did, broke the spider gears with bone stock 5.0! Had stock rims and tires (no slicks). It did take a lot of abuse before it broke however...
tarafied1 is offline
Old 12-19-2007, 09:44 PM
Scott H.
Scott H.'s Avatar
Scott H. is offline
Quick Reply: 87 8.8 in my 67
