carb
12-24-2007, 08:26 PM
carb
When my 302 is idleing the secondary jets are dripping gas.... what can i do to fix this problem?
12-24-2007, 08:40 PM
RE: carb
Is it a holley or edelbrock?
12-24-2007, 08:47 PM
RE: carb
You'r secomdarys diaphram spring may be no good?
Im just runing down the list of things it could be!
12-24-2007, 09:03 PM
RE: carb
What carburetor is it? Does it have 4 corner idle or a secondary power valve?
12-24-2007, 11:11 PM
RE: carb
it is a holly carb....
12-25-2007, 12:56 AM
RE: carb
Ok....
Which one? They make dozens, if nothundreds.
12-25-2007, 09:47 AM
RE: carb
rear float level is too high, or the needle is sticking open because you dont use the back barrels enough and the gas has gotten nappyfied inside the rear bowl.
worst case is 25 bucks for a rebuild kit with new needle/seat and gaskets
RE: carb
Check the needle valve for dirt holding it open. That or the float level is to high.
12-25-2007, 09:49 AM
RE: carb
Ha, 4 seconds between posts...
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Sminemann
09-17-2015 09:24 AM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
