Rad Size?
Old 12-26-2007, 11:55 AM
UBY289
UBY289's Avatar
Default Rad Size?
If I go from a stock Rad in 67 289 to 4 core Rad will I have to worry about the space between my fan and Rad.I have a clutch fan set up with a shroud will it still work.
UBY289 is offline
Old 12-26-2007, 02:31 PM
nassaubayman
nassaubayman's Avatar
Default RE: Rad Size?
It will fit, but you'll have to slide the fan and shroud in together. Or, bolt the shroud to the radiator, then lower the radiator, shroud and fan in all at the same time. When installed, my A/C compressor is VERY close to the shroud, but doesn't touch.
nassaubayman is offline
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
10-01-2015 09:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
09-29-2015 03:23 PM
Quick Reply: Rad Size?
