BAD vibration! - Page 2 - MustangForums.com
Old 12-30-2007, 09:41 AM   #11
Oxnard Montalvo
Boner Exspurt
Oxnard Montalvo's Avatar
Default RE: BAD vibration!
Quote:
well we got the 4 speed in and we have a bad vibration when running.
Did you replace the pilot bushing?
Which toploader is it?
I found out yesterday that a big block toploader behind a small block is a recipe for disaster. The pilot shafts on the big block trannys are shorter than the ones on the small blocks. The shorter shafts don't go far enough into the bushing to be safe due to the difference in the bellhousings. Seeing as I have this setup I have to pull my tranny to check if the shaft was changed when the tranny was installed.
Hell, I was thinking of putting a clutch in anyway.
Quote:
he says it catches at the top , the adjuster rod is most of the way in,, is all i need to do is extend it a little and check it ???
You want there to be play in the linkage, so you should shorten the rod until there is about 1/8" play between the rod and the fork before the fork comes in contact with the throwout bearing. Take the spring off the fork so you can move it back and forth. This should equate to about an inch of free travel in the pedal.
Oxnard Montalvo is offline   Reply With Quote
Old 12-30-2007, 09:51 AM   #12
lilrobo
good point about the tranny ,, we did see on top it said 65 to 73,, how else could we check ,, everything is smooth now
ok when i installed the setup ( z bar ) i adjusted the linkage most of the way in ,, if not all the way in ,, i think i need to extent it a little ,,,,we are going to check the free travel and total travel also ,, but sense it is catches at the top sound like it needs to be extended ???
lilrobo is offline   Reply With Quote
S197 Parts baddog671 Parts For Sale 20 07-26-2016 02:20 PM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 06:52 AM
What other parts should I be concerned about if my pinion bearing went bad? KingRando 2005-2014 Mustangs 5 10-02-2015 09:06 AM
I should've known better ChampInSD 5.0L GT S550 Tech 13 10-02-2015 05:55 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 06:26 PM
289, 28oz, 302, 50oz, 65, bad, balancing, bearing, difference, flywheel, mustang, pilot, speed, vibration, wrong
