Removing Pedal Assembly
I am removing my automatic transmission brake pedal assembly to swap it out for a manaul transmission brake pedal assembly.
Do I have to the remove the steering column to get out the pedal assembly?
RE: Removing Pedal Assembly
No, you can remove it without touching the steering column. IIRC, you may have to remove the driver's side fresh air vent to get enough room, but I may have had to do that for other reasons. While you have the pedal mount out, I'd convert to roller bearings.
Good luck!
Jeff
Good luck!
Jeff
I just remembered why I had to remove the air vent. I have a Mustang Steve cable clutch with a quadrant welded to the top of the pedal so I needed the extra room. I *think* you can just remove the retainting pin on the right side of the support and slide out the shaft and then slide in the new pedals with everything else still bolted in.
Jeff
Jeff
Thanks for the advice guys.
I was thinking about my project and I plan on painting the interior black, so I might as well remove the column.
I read that I have to take off the steering wheel to get the column off, after that the cover just slides off, right?
ORIGINAL: PReal
Jeff
jwog666
12-27-2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
