quick wheel quesiton
RE: quick wheel quesiton
yeah i looked. but each car is slightly different so it might not be the same for everyone. im thinking itll fit fine when the car is sitting on all 4 tires normally but when i jack up the front the wheels comes closer to the uca and i dont want it to rest on it. oh well. ill just get em and find out.
I would not put those on because those are not the ideal offsets and it will greatly limit the tires you can put on without rubbing.
with a 8" wide rim, you reallywant a 4.75" bs. With a 7" wide rim, you want a 4.25" bs.
note: a 8x15 with 4.75" bs will not fit on front because of upper control arm interference. You might have the same problem with the 4.5" bs, I'm not sure.
Dan04COBRA
09-30-2015 11:46 AM
