I actually puuled an engine!
Okay I know big deal for you guys but for me it was a huge step forward toward my Boss 302T (t for tribute).Considering prior to getting this car the biggest thing I ever done was a tune up. Anyway pretty pumped for now!!
RE: I actually puuled an engine!
Came out petty easy - probably should have pulled tranny at same time. But plan on dropping it this weekend. Plans right now are:
1. replace cowl (rusted out bad)
2. Stiffen shock towers
3. Put disk up front
4. Rapaint engine bay
5. Repaint car
6. Drop 331/347 stroker and new trans
Man getting worn out just typing it - but it will be sweet when done.
5. Repaint car
Yeah, once you've done it a few times it's actually pretty easy. The hardest part is getting it back in with the tranny already in, since you gotta line the input shaft splines up. I found it you put it in gear you can turn the driveshaft to run the input shaft to help line them up. You just gotta turn and push and turn and push, do NOT force it. It just takes time and patience, but when they're lined up it'll slide right in.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
