mechanical to electric fuel pump
Old 12-28-2007, 06:06 PM
SalikDDD
SalikDDD's Avatar
Default mechanical to electric fuel pump
anyone done this? i wanna switch to an electric pump with a safety/cut off in my 67. so far all i have is a block off for the mechanical on the engine, but what else do i need and what lph do i need to look for and regulator? thanks
SalikDDD is offline
Old 12-28-2007, 06:50 PM
67mustang302
67mustang302's Avatar
Default RE: mechanical to electric fuel pump
Holley's site in the fuel pump section has a lph calculator for engines. Definately need a FPR to control fuel pressure.
67mustang302 is offline
Old 12-28-2007, 10:34 PM
andrewmp6
andrewmp6's Avatar
Need to find a spot to mount it might have to rig up some sheet metal to mount on if space is a problem and keep it away from the exhaust.
andrewmp6 is offline
Old 12-28-2007, 11:55 PM
gothand
gothand's Avatar
Unless you're running a monster engine, any low pressure pump like a Holley Red will work and you won't need an external regulator. In addition to a safety switch, I'd run the pump off of a relay to be on the safe side. Mount the pump as low and close to the tank as possible, similar to the Ron Morris Performance setup.
Jeff
gothand is offline
Old 12-29-2007, 10:02 AM
JamesW
Moderator
JamesW's Avatar
The LP pump is a Carter P60430 unit, which was < $50 at Advance Auto
JamesW is offline
Old 12-29-2007, 02:27 PM
Colorado_Mustang
Colorado_Mustang's Avatar
^ I had one of those. It flowed worse than a stock mechanical pump.
I went through a couple of the Holley's (Blue and Red) before getting my currentEdelbrock pump. It seems to work the best for what I've used so far. You will definitely get what you pay for with electric pumps.
Colorado_Mustang is offline
Old 12-29-2007, 02:53 PM
JamesW
Moderator
JamesW's Avatar
I use the carter to keep my holding tank full, then use a high pressure pump to push it to the injectors.
JamesW is offline
Old 12-29-2007, 02:55 PM
67mustang302
If it's a carb'd setup, I'd just run an Edelbrock mech pump.
Old 12-29-2007, 05:35 PM
109jb
109jb's Avatar
+1 on the mechanical if using a carb.
109jb is offline
Old 12-29-2007, 11:00 PM
67mustang302
Unless you run an f/i blow through carb setup, then you want an electric that can put out good pressure to reference with the regulator.
LiquidDrink
09-29-2015 10:06 AM
uberstang1
09-20-2015 06:42 PM
SteelerNation82
09-16-2015 07:11 AM
jaiidutch
09-14-2015 10:29 AM
tramphardrocker
09-13-2015 08:56 PM
Quick Reply: mechanical to electric fuel pump
