which intake to choose?
so, i bailed on the cam idea now im thinking of swapping my intake.I have a professionaly products typhoon which has a power band of 1500-5500 i believe.If i swap to the summit brand on something else that has an idle and up band will i notice a big difference off the line and which intake is a good choice. god, I hate this i feel likea newb being so indecisive and all.
RE: which intake to choose?
You have the info you need....I would have said if it had after market heads.. and what not.The more experienced guys that i really want advice from are asking so obviously they have an idea about me car..anyways,,,,one last time.STREET CAR,STOCK HEADS,HOLLEY 600 VAC SECs,STOCK CAM (if i bailed on the cam obviously it was stock) you dont need the compression ratio to determine the intake and whatnot.77 where are ya man?need the advice from pros..
ORIGINAL: RGtheKid
Need more info! What heads are you running, compression ratio, carb, camshaft specs, what do you use the car for?
if you didnt already have the intake i would say buy something else, but since you do i would stick with it. its not worth the cash to swap over to something that may only be a tad better.
my advice? quit being a nancy and go get yourself a bigger bumpstick [8D][8D][8D][8D][8D][8D][8D][8D][8D][8D][8D]
ORIGINAL: mat11089
ORIGINAL: RGtheKid
I was going to help you but I guess you and your bone stock 302 know it all already.
