Pro touring vert gets pipes
Little update:
The chassis and sheet metal are finished so we loaded her up for a trip to Performance Exhaust. The car has so many chassis and suspension mods the exhaust needed to be scratch built. Now that it is all tacked together we will take it back to the shop and TIG weld it all with stainless rod.
Brent
"Build em' light and wind em' tight!"
www.cardomain.com/ride/2660122
www.cardomain.com/ride/2659961
Brent
RE: Pro touring vert gets pipes
Thanks for the comments.
The motor is a 408" Windsor with AFR heads, Wiand intake, KB pistons, Lunati roller valve train, etc.
The car was mini tubbed using stock inner and outer wheel houses. If you look at the frame in the pictures above you will see how they were laid into the existing frame and extend up above the floorpans a little so they could be completely welded top and bottom. The car has a torque arm, panhard bar, anti roll rear suspension with coilovers.
The wheels are Boyd Smoothie IIs 17 X 7 front and 18 X 10 rear. The Goodyear Eagle F1s on the rear have a 12" section width.
This cardomainpage shows a lot more of the details.
Thanks,
Brent
Thanks,
Brent
