Oil in coolant?
Old 12-31-2007, 12:34 PM
bluovalguy
bluovalguy's Avatar
Default Oil in coolant?
I finally got around to replacing my leaking radiator today. When I cut the lower hose off, a large clump of oil and reddish deposits fell out of the hose along with some drops of oil. I am thinking the head gasket is probably bad. What is the best way to test this? Also, could it be something else causing it that I could check for? Thanks much!!
bluovalguy is offline
Old 12-31-2007, 12:42 PM
bluovalguy
bluovalguy's Avatar
Default RE: Oil in coolant?
Kinda hard to see the oil.
This is the lower hose.
Old 12-31-2007, 01:09 PM
69thunder
69thunder's Avatar
If your head gasket is bad you will find a white creamy substance on the dipstick plus the car would have some overheating issues. Leak down test or pressurize the cylinder while looking at filler neck on the radiator. If you see bubbles in the coolant head gasket is bad.
69thunder is offline
Old 12-31-2007, 01:12 PM
bluovalguy
bluovalguy's Avatar
No overheating at all, and the dipstick is always normal. I have never seen coolant in the oil, just oil in the coolant.
When I get the new radiator in I will check for bubbles.
Old 12-31-2007, 01:56 PM
golden_eye
golden_eye's Avatar
Are you sure it's oil? When I replaced the originalradiator (from 1988)in my trucka couple yearsback it had a ton of brown sludge in it, but it wasn't oil. I may be just buildup over time but I don't know how old your radiator is.Mine was bad though, no wonder the thing kept overheating whenever I went above 60 .
golden_eye is offline
Old 12-31-2007, 02:06 PM
bluovalguy
bluovalguy's Avatar
Pretty sure it is. I dont have any overheating issues.
More good news, my new (used) radiator is to big, so now I have to use the old one if the shop can repair it.
Old 01-01-2008, 12:37 AM
andrewmp6
andrewmp6's Avatar
Do a compression check on every cylinder thats the only way to find a head gasket leak with out pulling the heads.
andrewmp6 is offline
Old 01-01-2008, 02:18 PM
Scott H.
Scott H.'s Avatar
Scott H. is offline
Old 01-01-2008, 02:30 PM
JMD
JMD's Avatar
Also, the PO may have used "Stop Leak",,,, this leaves nasty stuff in the cooling system.
As mentioned, it is pretty hard to get oil in the coolant unless you are running an "oil to water" oil cooler, and I doubt that you are running one. I don't recall seeing these on any car except for 3rd genCamaros and Firebirds...
In order for the oil to get into the water there usually needs to be a path wherepressurizedoil can be passed directly into the coolant. Short of an oil gallery opening intoa water jacket, (never heard of this, but might be possible?) I can't think of any other place on a SBF where this could possibly happen, especially since your oil is clean.
JMD is offline
Old 01-01-2008, 02:54 PM
golden_eye
golden_eye's Avatar
ORIGINAL: JMD
+1 on the Stop Leak. I'm almost positive that's what caused the sludge buildup in my truck's radiator I mentioned earlier.
The SSPMustangs and SVTCobras also ran oil-to-water oil coolers. I know mine has one.
Quick Reply: Oil in coolant?
