Power brake booster for 4 wheel disc brakes - MustangForums.com
Old 01-04-2008, 08:02 PM   #1
Angliagasser
Angliagasser's Avatar
Default Power brake booster for 4 wheel disc brakes
I have a 1966 mustang that I am building for my daughters first car. I put a Heidts front suspension in it, dics brake 9" and a 86 SVO motor and trany in it.Now I need toget a power brake booster and master cylinder. I was wondering what year of brake booster and master cylinderfrom a newer car with 4 wheel disc brakes will work in it?
Here are some picture of the 66 mustang 2.3 turbo engine swap.
http://www.turboford.net/ubb/ultimat...c;f=2;t=047607
Angliagasser is offline   Reply With Quote
Old 01-04-2008, 10:51 PM   #2
ozarks06
ozarks06's Avatar
Default RE: Power brake booster for 4 wheel disc brakes
I have a similar setup (Heidt's), but with a 4.6L motor and Explorer rear-end. I used the booster from an 89 Fox Mustang with V8. My master cylinder is from a 96 Explorer because I need the lines to exit on the driver's side (motor is too close). The Explorer has 4 wheel discs. Iused a Speedway proportioning valve (~$35, samevalve as Wilwood but a lot cheaper). I bought Mustang Steve's plans and pin to modify the pedal assembly (but I modified much more to use a hydraulic clutch). See his website. He can also give you the correct master cylinder (www.mustangsteve.com).
ozarks06 is offline   Reply With Quote
Old 01-07-2008, 07:47 PM   #3
Deviousfred
Deviousfred's Avatar
you put a 2.3L Turbo into the car?
Deviousfred is offline   Reply With Quote
Old 01-07-2008, 11:01 PM   #4
onegreedy
67 289 master cyl for 4 wheel disc brakes autozone sells them for like 80 bucks, or 150.00 with power brake booster i hve it on my
66 booster loos about the asame as a 67
onegreedy is offline   Reply With Quote
Old 01-08-2008, 01:05 AM   #5
Angliagasser
I put a 89 power booster, a 2001 master cylinder and yes I put a 300+ hp 2.3 Turbo SVO motor with a G3/4 turbo and 52 injectors. But before I let my daughter drive it I will take those injectors out and put the stock 38's back in it, the stock turbo back on it and takethechip out of the brain.
Old 01-08-2008, 11:52 AM   #6
Starfury
That's awesome But that unit won't fit in a 65-66. Not enough room. I believe the only way to get a dual bowl master and a booster in is to use a late model plastic-bowl type m/c.
Starfury is offline   Reply With Quote
Old 01-08-2008, 12:02 PM   #7
ozarks06
ozarks06's Avatar
Here's mine - 89 Fox V8 booster, 96 Explorer master cylinder (need lines to exit on driver's side for obvious reasons).
[IMG]local://upfiles/25918/780C2C2A6A30434CB79FF9E9E9E53D17.jpg[/IMG]
[IMG]local://upfiles/25918/E1B2F01F1D144E69946ACDD99371DF23.jpg[/IMG]
Old 01-10-2008, 12:39 AM   #8
Angliagasser
You have to remember I got rid of those pesky shock towers. So I have all the room in the world!
http://i259.photobucket.com/albums/h...02590116-1.jpg
Old 01-10-2008, 08:39 AM   #9
ozarks06
ozarks06's Avatar
Quote:
ORIGINAL: Angliagasser
Me too but that Big Ugly Fat Fellow pretty much uses up all that newfound space!
[IMG]local://upfiles/25918/07F1A3F7356B4D25BF07B734BBF1C66E.jpg[/IMG]
Old 01-10-2008, 10:04 PM   #10
Scott H.
Scott H. is offline   Reply With Quote
Help with 66 front end that lifts up and goes out of alignment Cavedawg Classic Mustangs (Tech) 6 09-17-2015 10:51 AM
AOD - repair or T5 swap? CarrieS 5.0L (1979-1995) Mustang 6 09-01-2015 02:00 PM
Brake Problem FD725 4.6L V8 Technical Discussions 3 08-23-2015 07:43 AM
Unidentified Rear Disc Brakes - Need Help!! Fast-Hands 5.0L (1979-1995) Mustang 2 08-19-2015 07:54 AM
New Guy on the Forum with braking issue FD725 New Member Area 3 08-11-2015 04:43 AM
1966, 66, 67, booster, brake, brakes, clutch, disc, disk, forum, hydrabooster, hydraulic, lincoln, mustang, power, wheel
