Oil pan question...
Oil pan question...
So... I'm putting in a H.O. 302 out of an 1987 Gt into my 1967 Coupe. Looks like I have to change the oil pan to a front sump pan. Do I have to worry about the oil pump and pickup? Will I need a different oil pump/pickup?? Thanks...
RE: Oil pan question...
Yes, you will need an early style pickup as well as the early pan.
Also, you will need to make sure you have a place for a dipstick.
You will need to drill a hole in the timing cover if there is not one there already,and there won't be...
