4x4.5 rotors?
RE: 4x4.5 rotors?
drill your own, it can be done if you start by making a jig. I have redrilled rotors and hubs for several applications including my Jaguar IRS project. Here is an excerpt from my Jaguar IRS page and the technique I used should work for you.
"When I first suggested to some other car enthusiasts that I was planning to drill the pattern myself, I was told not to drill the pattern because it would be almost impossible to have all 5 holes be in the correct spot. I pondered the issue and, at first, thought about making a 10-hole jig. (5 holes each pattern) Problem is, I still would have a hard time getting all 10 holes in the correct position. One day while contemplating this issue, I had an epiphany, instead of making a 10-hole jig, make a 3-hole jig and rotate it from position to position. I made the jig (Homemade Tool # 4) by drawing 2 circles, a 4.75ā€¯ circle with a 4.5ā€¯ circle inside it. I then measured the distance between two studs on the Jaguar wheel flange and plotted those 2 points on the outer circle. Using these two plotted points I measured between them and plotted a center point on the inner circle. The drawing was then transferred to a piece of steel and the three holes were drilled out, .5ā€¯ inches on the outer ones and .125ā€¯ for the center hole. The jig can now be bolted to the flange and a pilot hole drilled. The beauty of this jig is that even if the pilot hole is not perfectly centered, as long it is on the 4.5ā€¯ circle, it will be in the same location between the two studs on all 5 holes, giving a perfect star pattern. After creating the jig, I purchased a cheap Chevy rotor and drilled out the Ford pattern to ensure that the jig was accurate prior to drilling the hub."
Omgitsa88Stang
10-05-2015 07:33 AM
09-16-2015 07:53 PM
