back to the lift
back to the lift
well we are going back to the lift this weekend ,, my sons 65 still isn't right we are getting chatter on take off and it has a noise just sitting there ( i think i need to adjust the clutch more ) and the speedo is off 10 mph ( need to check the gear ) ,, we are going to change the pressure plate ( a new one already ) and change the clutch ( a new one too ) to make sure that they aren't the problem ,,, anything else to check ??????? one of you guys said something about input shaft being too short ,, how can we check that ??
thanks for all the help so far guys
RE: back to the lift
(1) Bad pilot bushing/bearing?
(2) Bad transmission input shaft bearing?
(3) Contaminated clutch disc surfaces?
(4) Pressure plate not torqued down evenly (and has warped)?
I had a car where item #2 was a problem that recurred at about every 50,000 miles. I suspect that the root cause was either a bellhousing or tranny case that wasn't drilled quite right, and the tranny input shaft wasn't quite concentric with the crankshaft. Have you replaced the bell? Some aftermarket bells and scattershields aren't all that accurately made.
Norm
Norm
yeah right now everything is new i am going to replace everything also again the pilot bearing is new also now the input shaft might be bad how can i tell????? and a good friend told me that when he changes a tranny he does the bell housing separate ,, he does the bell housing andthen the tranny is that the way to do it ??? i was doing them together ,,,,
thanks
thanks
musnicki
09-23-2015 07:11 AM
Insidian
Carolina Regional Chapter
09-08-2015 05:33 AM
