help!
Old 01-09-2008, 07:29 PM
gibsonxplayer88
gibsonxplayer88's Avatar
Default help!
so i went out to start my car today when i got home from school and i noticed there was water all over the center counsel and gear selector. now there looked like there was some water leaking from the rear view mirror by where it meets the windshield. so could there be a leak in the weather proofing around the window? whatever it is i really need to get it fixed soon before spring. (chicago area gets tons of rain) i dont want to ruin the interior with water because its the original leather and its perfect.
any ideas what it could be?
gibsonxplayer88 is offline
Old 01-09-2008, 08:00 PM
Mustangdemon67
Mustangdemon67's Avatar
Default RE: help!
yeah, it might be the stripping around the windshield. just take off the chrome lip around the outside of the window and see if the rubber is old and cracked. if it is, then its time to replace
Mustangdemon67 is offline
Old 01-09-2008, 10:18 PM
mustangmatt63
mustangmatt63's Avatar
Default RE: help!
Sure sounds like the weatherstrip to me.Take the trim loose and pour some water over it to see if its leaking! If it is replace the weatherstripping.If your headliner needs replaced this would be a good time to do that also as the window will already be out!Good Luck![8D]
mustangmatt63 is offline
Old 01-09-2008, 10:37 PM
ninteen66mustang
ninteen66mustang's Avatar
Default RE: help!
In the mean time, get a car cover...
ninteen66mustang is offline
Old 01-09-2008, 10:59 PM
jlp66stang
jlp66stang's Avatar
Default RE: help!
Bedding compound might be a temp fix if the rubber is not cracked.
jlp66stang is offline
Old 01-10-2008, 12:03 AM
flyingfool
flyingfool's Avatar
Default RE: help!
could go get the hose and soak your car down and look for drips or stuff. thats how i found my leaks around my windshield
flyingfool is offline
Old 01-10-2008, 12:41 AM
gibsonxplayer88
Default RE: help!
thanks everyone. i took off the trim and right in the middle the rubber was all cracked so i ordered new weather stripping and hopefully will have it fixed in a few days.
