Steering column removal..
Old 01-13-2008, 07:55 PM
baddog671
baddog671's Avatar
Default Steering column removal..
How should I go about removing the steering column on my 67? I had the gearbox serviced awhile back and now I would like to remove just the column to clean it up and paint it, its nasty. If it matters, I have the early 67 style which resembles the earlier years, with the gearbox and shaft 1 piece.
I have my steering wheel off andjust removed the U-shaped bracket holding it to dash, what next?
Thanks
Nic
baddog671 is offline
Old 01-13-2008, 08:11 PM
Mustang Dad
Mustang Dad's Avatar
Default RE: Steering column removal..
Disconnect the wiring at the base of the column, wrap both hands around the column, give it a good yank. Should slide right up and off.
Mustang Dad is offline
JMD
JMD's Avatar
I can't say for sure because my son disassembled () the old column and box from the 66, and we didn't go back stock, but I am reasonably sure that what follows is a close representation of what has to happen.
There will be a bracket that holds the column to the floor and something like a clamp that holds the column tube to the box.
I am for sure on the floor place, but not so sure on the clamp, just supposition..
JMD is offline
Old 01-13-2008, 09:07 PM
mustangmatt63
mustangmatt63's Avatar
If you have the bracket to the dash removed you just need to disconnect the wiring and it SHOULD pull straight out!!You might have to give it some muscle but it s supposed to come right out! Good Luck!
mustangmatt63 is offline
Old 01-13-2008, 09:27 PM
baddog671
baddog671's Avatar
Ok, I think i know the wiring your talking about, so I'll get that off and see if she comes loose. I have a feeling it'll fight me alittle though.
Got another question. There is a large grommet thing (like a steel plate with a rubber middle) at the base of the column that seals it tight on the firewall. Anyone know the name of this?
Old 01-13-2008, 09:29 PM
JamesW
Moderator
JamesW's Avatar
There's a bearing at the top of the column that aligns the steering shaft in the middle. Sometimes they can be sticky. Take apart your upper column (turn signal cam, bearing retaining plate.... You may have to wack the column a little with a plastic mallet to break loose that stuck bearing.
JamesW is offline
Old 01-13-2008, 09:34 PM
baddog671
baddog671's Avatar
James, I actually have the steering wheel off and all that crap in there that holds it in place. I figured while I have it out I'll clean up the column...
Old 01-13-2008, 09:39 PM
RolandT3Speed
RolandT3Speed's Avatar
FYI: You can't remove the wiring without carefully pulling the pins out of the plug.
Handle it with care, it's 40 years old a brittle. I don't know if anyone make a replacement.
RolandT3Speed is offline
Old 01-13-2008, 09:43 PM
JamesW
Moderator
JamesW's Avatar
There's also a rubber "boot" down at the bottom of the shaft at the end of the column. if that is old, it can be hard to pull up off the shaft.
JamesW is offline
lincolnshibuya
12-08-2020 01:49 PM
CS2007
06-25-2019 09:45 PM
ChampInSD
10-02-2015 04:55 AM
allenmaty
09-24-2015 09:17 AM
stark777
09-21-2015 12:46 PM
Quick Reply: Steering column removal..
