Questions for the experts!!
RE: Questions for the experts!!
To R & R the timing cover I think you will only need to remove the 2 front bolts of the oil pan that thread into the timing cover itself.
You will need to get access to the timing cover, the alternator, PS pump, and A/C compressor will need to be moved out of the way. The harmonic Balancer will need to go, (you will need a puller for this).
Possible problems might include the water pump bolts breaking. They thread into the block, and through aluminum, (dis-similar metals)and are subject to corrosion. Take your time with the bolts if they don't come loose easy.
ORIGINAL: 66 FastBach
i already have removed everything to do the water pump, so since im already almost there i might as well fix it now.
Good Luck!
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
