leaf spring replacement
#21
RE: leaf spring replacement
A situation is different. Mine of course were a MF. Talk about getting dirty and you will need air tools to make it easier. But well worth it and like someone said before replace the shocks while your at it.
#22
the front bolts arent that difficult if you know how to deal with them
i had one that was seized tight and it didnt take me long to get it out and i didnt have to do any cutting
i used a big C clamp and a metal die i had thats about 3 inches across and 2 inches thick
the die has a hole in the center, so i duct taped a steel plate across the hole so the clamp would have something to push against
i placed the die over the head of the bolt and then used the C clamp to press the bolt out
worked great, and no molten rubber
#23
I tried a big C-clamp too (12") an it started denting the frame before the bolt would budge..
I know another member on here said he tried using a hydrolic press that could press 2500psi or something like that and it didnt budge..
