Vacuum Lines
Vacuum Lines
Hey folks
I've got 2 lines right now that aren't going anywhere. The first is coming from the front of the Edelbrock Carb. The second is coming from the firewall. Anyone able to tell or better yet show me in a pic where these lines should go? Both are just laying there going nowhere right now. i've looked through the 67 shop manual a couple times now and cant find where these should go. Thanks.
RE: Vacuum Lines
im not sure on that, i dont have mine hook up, but i think one heater hose hooks up to our intake manifold and looks like thats ones there, and i think one hooks onto the water pump but im not quite sure
RE: Vacuum Lines
that pictures fine , it looks like your POs disconnected your heater and just connected your water pump and intake together instead of blocking them, so your heater is probably bad, id rebuilt it and might need a new blower motor, im going through the same thing right now.
RE: Vacuum Lines
Yeah.. I'm not too knowledgeable yet on the engine so kind of stumbling around. I need a good book on the small block and 289. The car is going to be striped next month and everything rebuilt including the engine. I'll have the help of my father, friends and others over the next months. I have a lot of learning ahead of me.
Thanks for the help!
RE: Vacuum Lines
Yeah, that firewall hose is the heater hose that's supposed to connect to the fitting on the intake. The other one is the PCV valve vacuum line that runs to the PCV valve on the p-side valve cover.
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
