Opinions on this welder
RE: Opinions on this welder
MIG- automatic wire feed with a gas shield. Requires a welded and a bottle of inert gas to supply the shield. Leaves a clean comlete weld.
Gassless- also an automatic wire feed, but this uses a special flux-cored wire. Think of a hollow tube filled with "Flux" the flux burns at the same time as the wire and provides the "shield". This method leaves a residue from the flux that must be removed.
From your posts it is apparant that you have little or no experience with welding. As someone else pointed out, local community colleges usually have adult education classes and welding is quite often on the list. I'd suggest you attend one of these first, or ave someone else do the welding for you.
ORIGINAL: honeygoldcoupe
I do not know how to weld..yet. I have limited space, no access to 230v
FWIW, I got a brand new Lincoln 175 off of Ebay for $400 and picked up a re-certified tank for another $100. Works great!
Jeff
if you get a welder, make sure it has access for a argon bottle. the flux core wire welders with no bottles dont work for crap. youre not gonna be happy with a welder unless you spend at least 4 or 5 hundred on it. we got ours when it was brand new in like 2000. a 130xp wire feed Millermatic. it was a few grand. lincoln or miller ftw. nothing else compares. i know a little about welders cause i worked with this guy who is super picky on the quality of tools he gets and he bought his miller tig welder for like 10k. dont buy one of those cheapass ****ty welders for like a couple hundred bucks. they wont work right and youll just get pissed off at it for burning holes in everyhitng you weld.
If you want to see what I want to patch look at the "gotta love it" thread started today by slick66stang. I really don't think a gas welder is in the cards for me. I'll look at wire feed. What does the wire do? There is a difference between "wire feed" and flux core wire?" Forgive the basic questions here. Just learning and I can't find a whole lot online that educates me without trying to sell me a particular welder. All the welding sites seem to have their own agenda.
Stay away from thoes cheaper units (Clark, auto arc, lincolns HD series, lincolns weld pac series and hobart) Go to your local welding distributor and ask to DEMO a lincoln 140 and miller 140. Ask their advice, they are there to help (i hope). If you have never welded i would recomend the Millermatic 140, there about 625.00, 30.00 for wire, 189.00 fo 80cf cylinder and 45.00 for the gas fill. plus you have the option to do allum in the future should you feel compelled to so.
MIG stands for "metal-inert-gas". All welding involves a "puddle", the puddle is the molten steel. My experience with 120v welders has not been that great. They draw alot of amps, and will trip your 15a household outlet frequently. I would stay away from the fulx core wire, as mentioned earlier in the post, the flux shields the arc, and needs to be cleaned off after welding. The "hard-wire" is cleaner, and IMO, better suited for sheetmetal. The flux core generates more heat due to the flux vs bare wire with a 75/25 shielding gas.
I may be beginning to come to my senses. Looks like $600 to $1,000 to get what I need and then I have to learn how to do it. I'll visit the local Miller distributor tomorrow and check it out. I think I may ask them if I would be better off just having having a weld shop weld the patches in. There is also a small repair shop here and the owner's specialty is vintage Mustangs. I'll check with him about welding the patches. There are less than 10 small patches. I have never needed to weld anything before and I may never need to weld anything again...at least not enough to justify the learning curve and cost. Since I worked in a body shop years ago I do have the skills to straighten metal, do
Bondo, prepare the car for paint, disassemble, reassemble, etc. I'll probably justdo the work I already have the skills forand hire thewelding done. I'll let you know what happens.
If that's the route you're going to take, and you have the skills to "fit" the patches, you can save alot of money, if all the guy has to do is walk in a weld..... If you're in S. Florida...I can help you out...
