Instrument panel lights
My instrument panel lights are not working at all. The worked before christmas and now they dont. I installed a sony cd player and that was the day they quit working.What is wrong?
RE: Instrument panel lights
Sounds like you disconnected something while installing your stereo. Look under the dash where you were hooking up the CD player and see if you disconnected any wires.
As JamesW said it sounds like you accidently knocked a wire loose while installing the stereo.Should be a simple fix just look for a loose or disconnected wire!Good Luck!
[IMG]local://upfiles/72436/E7CF5FE345824CF2A9DF1E3CC3C4188D.jpg[/IMG]
Well when we were installing the radio we found like an extra ground i think. So we bolted that down. Then the lights didnt work, but i took it off and they still dont work. I will check the wires tomorrow.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
