1967 engine swap
1967 engine swap
looking at getting a mustang that currently has a 6 in it but I was told that it had a 8 in it to begin with, do the motor mounts have to be changed in order to go back to a v8 and if so what is required ie welding etc.
RE: 1967 engine swap
Let me Begin by Welcoming you to the Forums!Does the Stang have 5 lugs?Do not take someones word on what it originally had without verifying it.If you get the Vin# I can decode it for you.I can tell you that if it originally had a V8it will have 5 lugs.Do you have access to the vin or a picture of it?If it originally had an 8 you should have no problem changing it back!!A 289 or 302 will go right in!!Good Luck!!
[IMG]local://upfiles/72436/3A07A9D4A6D542F8A993F398F1EC9D30.jpg[/IMG]
