65 aftermarket help.
Old 01-23-2008, 06:34 PM
greenbay stang
greenbay stang's Avatar
Default 65 aftermarket help.
Here we go again. I am restomoding my 69 fastback and my friends 65 fastback at the same time (I got roped into it). He stopped in today and seen I have all the metal work done: floors, transition pan, trunk pans, quarters, front fenders, doors, rear frame rails, etc. There is not a lot of original car left. Any way I though I could see the light at the end of the tunnel when he said he would like a 67 shelby scoop on the hood, side scoops, and rocker skirts. Does any one sell the rocker skirts separately and has any one ever put a 67 scoop on a 65 hood? Will I have any problems with it?
greenbay stang is offline
Old 01-23-2008, 06:39 PM
67t5ponycoupe
67t5ponycoupe's Avatar
Default RE: 65 aftermarket help.
Try Mustang Plus for the side skirts. I think they sell them separate. As for the scoop, tell him if he wants it, to buy a fiberglass hood with the 67 shelby scoop in it. It will be a lot less work for you.
67t5ponycoupe is offline
Old 01-23-2008, 06:46 PM
67t5ponycoupe
Side skirts https://www.mustangsplus.com/xcart/home.php?cat=2366
Scoops https://www.mustangsplus.com/xcart/home.php?cat=2645
Hoods https://www.mustangsplus.com/xcart/home.php?cat=2350
Side scoops https://www.mustangsplus.com/xcart/home.php?cat=2402
67t5ponycoupe
I'm sure other vendors have them too.
Old 01-23-2008, 07:04 PM
mustangmatt63
mustangmatt63's Avatar
I would get him to buy the Shelby style hood for the 65 from mustangsplus or laurel Mtn mustang(NPD)is too expensive for those,as far as the side scoops I believe one of those places sells those also!And I know that NPD carries the rocker moldings and clips if thats what you are referring to!Good Luck with it!If you can talk your buddy into that hood you will save yourself a serious amount of work!
mustangmatt63 is offline
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
NYstang
09-30-2015 09:56 PM
mustangheaven
09-29-2015 11:00 AM
09-24-2015 09:18 PM
Quick Reply: 65 aftermarket help.
