351c heads on 351w?
351c heads on 351w?
how hard would it be to put 351c heads on a 351w? i saw this done on a past Hot Rod magasine(i beleive it was a nascar engine though..) and online. what would the benefits be?
RE: 351c heads on 351w?
http://www.themustangshop.com/clevor.cfm
its doable, tho i think with whats available in aftermarket alum heads, its a questionable job.
ORIGINAL: racin66coupe
is this even possible?
+1 for aftermarket heads. It makes no sense today to put clevo heads on a Windsor with all of the aftermarket heads for the windsor that are available.
im a romantic, i find it awsome to swap factory parts like that and to build power with ford castings. its exotic, its different, its definately cool.
one of the people on here had a 408 or 427 with 351C 4v heads and i never got to hear how it ran. i'd like to know
ORIGINAL: my77stang
ORIGINAL: my77stang
to me, its just the weight of cast iron heads and the manifold options being limited not to mention the expense of setting it all up...if you can do the head work yourself great. If not I'd be buying a set of AFRs or whatever that are bolt on ready to go.
im also on a budget.. so if it isnt that hard to do the cleveland swap,i think i might plus, i might have some connections for porting work on the intake. im also thinking of turboing the motor and a 408 stroker, so with cast heads i wouldnt hafta worry about warping as much. has anyone done the head swap on here?
yeah there are, just gotta find em. there are articles with diagrams on what needs to be done, but its all pretty simple stuff. the hardest thing is drilling out a square hole in the deck surface of the head so you can install a freeze plug. that pretty much needs to happen on a drill press, but everything else is super easy
