Any Ideas on Fabing Cowl Kick Panel on 1970
Old 01-27-2008, 02:02 PM
palerider
palerider's Avatar
Default Any Ideas on Fabing Cowl Kick Panel on 1970
I've got the cowl off my 1970 and am replacing with a donor. Need to fix vent opening (cowl kick panel) also rusted. They don't make a replacement part and will need to fab something up. Any suggestions. The po5 15 on it now was when I tokk out lower dash last year - just put it on hoping to slow down rust. Need to fix this before I replace the cowl.
[IMG]local://upfiles/29873/D2FAEB67A4AD4CF7B0B87DD4C518ADB8.jpg[/IMG]
[IMG]local://upfiles/29873/AA81F2595CEF4E5095D089DC3811CE71.jpg[/IMG]
palerider is offline
Old 01-27-2008, 06:08 PM
RGH69
RGH69's Avatar
Default RE: Any Ideas on Fabing Cowl Kick Panel on 1970
Yep, we had the same problem. We looked everywhere and unfortunately we could not find that panel. We just welded over the whole panel with a patch. We are not planning to put the vents back in.While the Upper cowl was off we could give the inside a thorough coat of rust encapsulator and rubberized truck bed coating.
RGH69 is offline
Old 01-27-2008, 08:50 PM
palerider
palerider's Avatar
I'd like th put the vent back in - like having fresh come in as you drive. Guess it's time to paly with the welder and see if I can rig something up.
Old 01-27-2008, 10:02 PM
Reverb
Reverb's Avatar
Can you fabricate something out of this?
http://mustangsunlimited.com/itemdy00.asp?T1=M136LH+01
Reverb is offline
Old 01-28-2008, 06:39 AM
palerider
palerider's Avatar
Proabably not. Vent opeing on the kickwall are a lot larger than the hats (vents) on lower cowl. Thanks for posting though.
mustangheaven
01-03-2016 11:20 AM
b8checker
10-08-2015 12:55 PM
Explosive
10-02-2015 07:45 AM
b8checker
09-30-2015 07:11 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: Any Ideas on Fabing Cowl Kick Panel on 1970
