throttle linkage - fordmuscle/faq question
Old 01-27-2008, 06:05 PM
bradleyb
bradleyb's Avatar
Default throttle linkage - fordmuscle/faq question
I was checking out the faq and wanted to do the throttle linkage DIY project. I easily found everything but the 1/4" x 28 rod - finding machine thread rodbecame a mission until I found an industrial placein south el monte that has anything and everything - industrial pipe and steel on rush and mission.
Anyhoot, on to the question - why are they using the rubber washers? I found some Moroso washers that look awesome for $6 and left the rubber/plastic piece in the rear since it is already 1/4" (I figured why bother with the reducer, it was a piece of metal hitting it anyway), putting on these washers w/rubber pieces takes away from the look and I don't see any reason for it, so why bother?
Any ideas, I'll post pics later tonight?
bradleyb is offline
Old 01-27-2008, 06:10 PM
bradleyb
bradleyb's Avatar
Default RE: throttle linkage - fordmuscle/faq question
here is the thread i was referring to in the faq - it does look sweet and for the 25 or so advertised was way cool, since my car is a project car with my son it was another easy way to have a bit of fun with the achievement of having done it yourself
https://mustangforums.com/m_3543660/tm.htm
bradleyb is offline
Old 01-27-2008, 11:23 PM
bradleyb
bradleyb's Avatar
I just reviewed the ford muscle article a bit more and it looks like the rubber washers are used in lieu of the stepp washers. I am going to bail on the rubber washers in the front but keeping them in the rear (where I am keeping the stock plastic piece in place and just using the washers on both sides of this piece).
bradleyb is offline
Old 01-29-2008, 12:34 AM
bradleyb
bradleyb's Avatar
finally got the camera back from my daughter. I went with just using the Moroso washers in the front with the screw and nut; I used the washers with the rubber in the back and left the plastic piece in place. It is very tight and smooth, goes through the entire range very easily and without any force, the heim joints work great. The Moroso washers were $6, the bolts/washers nuts a couple bucks, the 1/4 x 28 rod a couple of bucks, heim joints $11, and the brake line I had left over from another project
[IMG]local://upfiles/34309/23350A15F3FA446C814856B8BE56A109.jpg[/IMG]
[IMG]local://upfiles/34309/D5FBB32C35D24062B6EB273F2EDE37D8.jpg[/IMG]
[IMG]local://upfiles/34309/0849F1FA072747D7960E18BAE6830302.jpg[/IMG]
bradleyb is offline
Old 01-29-2008, 12:45 AM
valley firearms
valley firearms's Avatar
Looks great!
[align=left] [/align]
valley firearms is offline
Old 01-29-2008, 12:44 PM
bradleyb
bradleyb's Avatar
thank you valley, getting sooooooo close!
bradleyb is offline
Luke9222
10-22-2015 11:55 PM
GimpyHSHS
09-18-2015 12:27 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: throttle linkage - fordmuscle/faq question
