starter
RE: starter
If its turning over the starter is working.
Check your points,plugs, rotor and cap.
check fuel filter make sure gas is making its way up to the carb.
If it has fuel and spark check timing make sure it hasnt jumped time.
RE: starter
Unless she's cranking real slow, she might be flooded--try to crank it after several hours rest (could be the car or you). Also I highly recommend Starting fluid sprayed down the carb. Itwill give the cylinders something immediately to fire off when cranked if any kind of spark is there. Otherwise, as already mentioned,it's either spark, timing or fuel problems.
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
