Do they make these?
RE: Do they make these?
haha i just got that after i responded. i have not seen any but i heard they do not really work on these older cars, if i were you id go with a more period correct looking one. get some flexible ducting and attatch it to the original style air cleaner housing (right terminology?) and run it right behing the radiator, if you ask me, it looks a lot better than ricer looking intake on it
ramairbox or a home made setup? for a home made setup (ill go into it more thoroughly) take you air cleaner assy- and attatch air ducting to it - (i prefer it in black but this is all i found) then run it rught behind you radiator. you can put an aftermarket air cleaner in it.
ramairbox or a home made setup? for a home made setup (ill go into it more thoroughly) take you air cleaner assy-ramairbox or a home made setup? for a home made setup (ill go into it more thoroughly) take you air cleaner assy- and attatch air ducting to it -http://i154.photobucket.com/albums/s...e/IMG_0034.jpg (i prefer it in black but this is all i found) then run it rught behind you radiator. you can put an aftermarket air cleaner in it.
WTF?!?!?!?!?!?!? here, ill try again. you can delete the others
ramairbox or a home made setup? for a home made setup (ill go into it more thoroughly) take you air cleaner assy-ramairbox or a home made setup? for a home made setup (ill go into it more thoroughly) take you air cleaner assy-http://photobucket.com/mediadetail/?...p;pageOffset=8 and attatch air ducting to it -http://i154.photobucket.com/albums/s...e/IMG_0034.jpg (i prefer it in black but this is all i found) then run it rught behind you radiator. you can put an aftermarket air cleaner in it.
