1965 Mustang Radio Patch Panel = A Real Pain!!
Old 02-26-2009, 09:21 AM
abarli65
abarli65's Avatar
Wow.. that looks clean. I like it.
So how far out from the main radio hole did you go with the patch? I hope I worded this question correctly.. Basically, how big was the patch? I am picturing that you cut the patch down to a smaller square to only cover up what was needed?
Man, great job, cause I cannot tell where the patch is.
Here is what I am going to be dealing with...
And the new patch...
abarli65 is offline
Old 02-26-2009, 07:21 PM
92ponyranger
92ponyranger's Avatar
Well, essentially what I did is trim the patch down to just big enough (left to right) to cover the holes that were cut and drilled into the panel. I cut it just above the little bend above the radio area so I would have a flat area to weld to and trimmed it to a nice flat below the radio. In other words...trim yours kinda the size of the "dirty area" where the last plate was and go a bit higher that the bend above the hole. I used a MIG welder and did the spot weld method all the way around to prevent warpage.
92ponyranger is offline
Old 09-02-2010, 02:41 PM
abarli65
abarli65's Avatar
Default finally got around to it
So I am finding that restoring a mustang is not an overnight chore... Loving every moment, but this goes to show how my mind gets way ahead of the actual work.
Took your advice and just chopped out what I needed to.. My welding has "improved" to the point that I felt comfortable enough to do an area that was not to be covered with carpet.
Turned out pretty good; however, the indention area on the patch is not as wide as the original. Not sure if there are other brand repops out there. It is nothing that I cannot make look good after some filler primer and paint.
Thanks again for your info!
abarli65 is offline
Old 09-02-2010, 02:52 PM
Adrenolin
Adrenolin's Avatar
Great job and looks super
Adrenolin is offline
Old 09-02-2010, 09:59 PM
JMD
JMD's Avatar
Looks way better than just "good enough" to me.
Nice job.
JMD is offline
Old 09-03-2010, 06:55 AM
tx65coupe
tx65coupe's Avatar
I wish my dash hadn't been hacked too for a POS Craig tape deck. I just cut it to fit a single DIN CD player. At some point I would like to patch it and get one of those retro type stereos.
I was planning on using JB Weld when I do this. It looks like that will work. Do you have any pictures of yours gothand?
tx65coupe is offline
Old 01-21-2020, 06:47 PM
steve93101
steve93101's Avatar
Default Easy repair good for a driver... no welding needed
Made this for my own 65 fastback.....
http://www.mustangdreams.com/repair-plate.htm
1965 1966 Mustang Repair Plate
steve93101 is offline
djbigskrilla
09-20-2022 01:04 AM
WDScott
08-17-2015 06:38 AM
iamgobono
08-16-2015 10:50 PM
daytooday
08-11-2015 09:22 AM
89blueslug
08-10-2015 07:20 AM
Quick Reply: 1965 Mustang Radio Patch Panel = A Real Pain!!
