got a new block
RE: got a new block
I talked to jegs, and they have the package in their system, but do not have any prices for it yet. I will probably call edelbrock tommorrow and see what is the deal with the package and the price.
RE: got a new block
ORIGINAL: javier146
I just saw the kit and it does use I beam rods, I will try to ask if they can exchange them for H rods, where did you buy the stroker kit from?
Don't forget to get your stroker kit balanced!
I bought our kit from The Mustang Depot, the Eagle kit you are getting is probably of a better quality though... The TMD kit we got was all forged and H-beam rods for about $1,200 if memory serves me... +$200 for balance...
RE: got a new block
ORIGINAL: javier146
Ok, what do you mean balance the stroker kit, you cannot just install the kit as it is? What do they actually do to balance it or can one do this without machines?
Some kits are sold "balanced" others are sold "unbalanced". If the kit say neither balanced or unbalanced you can assume unbalanced. The cost for balancing is about $200.00 + or-.
It does take a special machine. And thecrank is"dynamically balanced" (spun) using "bob-weights" to simulate rods and pistons, the weights of which are taken into account.
RE: got a new block
Take your balancer, crank, rods, pistons, pins, flywheel etc to a shop that does engine balancing. They weight everything, put the crank in a machine with weights on it and spin it, then add/remove weight to balance the assembly. If you don't you're asking for serious trouble.
Also, double check the block before you get a roller conversion cam. It may be a roller block that someoen put a flat tappet cam in. Factory roller cam setups are cheaper than conversion, so there's no sense in getting a more expensive setup that's not neccessary.
Matt's 95 Stang
10-05-2015 07:16 AM
